1. I have two monitors, and I like to keep the VRay frame buffer on the secondary monitor while the Maya window is on the primary monitor. However, whenever I change the resolution (pixel dimensions) of the render, and then render again, the frame buffer jumps back over onto the primary monitor, along with the Render history. I waste quite a bit of time manually moving both the frame buffer and the history back over onto the secondary monitor each time I change the resolution.
2. Completely unrelated question: is there any way to set a keyboard shortcut for saving the new render into the Render history? That would speed up my workflow quite a bit.
