vray frame buffer not showing progress
This worked for me.
Ok, the thread is 1,5 years old, but the problem is the same for me. My experience is, that it can´t, in my opinien, be caused by settings outside the max-file. I have some scenes where all works fine and others, where I have the same problem as described above. Who has the time to uninstall and reinstall the software when stucking in a project? So I opened two sessions of MAX side by side , one with a scene with working VFB and one with a scene with the error. Then I compared step by step all the settings in the render setup window. Yes, ALL the settings. All pull down menus in expert mode if available. No succes- even if all settings are the same for both scenes. The same I did with the environment window and I tried if with sunlight or domelight and with differen types of cameras. Only one time I thought I found a fix. After I hit “Rendering-->Rendered frame Window” it stops showing the progress in the VFB, which worked fine. But only one time. I have also the same experience, that the “Rendered Frame Window” of MAX is always working fine, even when the not working VFB is open beside it. Sometimes I had the experience, that a new scene works fin and after some time of working with it teh error occurs. I will search a little more, but I someone have a solution which is not published here - please do it now!
