VRay Frame Buffer & Time Stamp
I have using VRay’s Frame Buffer with the filename and rendertime stamp turned on. No problem on the monitor but when I save the image that info is not stamped on the image. Has anyone else had that issue.
Past several versions with Max 6.
JoeD
You must have them turned on in the System rollout also.
Thanks that did it.
JoeD
