Vray Frame Buffer Window Button ?
Is there a way to place a “Show Last VFB” Button on the toolbar or Assign it to a shortcut? I started using the Vray FB with SP3 and the Linear Workflow, but since I’m quite used to closing the render window and opening it when I need it, it’s really a drag. Also, since I render out different frames, it would be nice if the VFB window title showed which was the frame number, and not get it from the frame stamp…
I guess this could be moved to the wishlist.
You can right-click in a viewport and choose V-Ray VFB from there.
