Vray Frame Buffer with fields .... problems ...
Is it me or when you make the fields active, the resulting render will be show only in the first top half of the Vray Frame Buffer ???
Also, if I try to save the separate G-Buffer channels or the vrimg image without using the save file from the common tab, I will also only have half of the image in the saved image files ???
Last thing, if the Render to memory frame buffer is unactive, the vrimg and all the G-Buffer channels will not be saved ??
Max 7.5 + Vray 1.47.03
