Vray Frame Buffer
Hi
The problem as follow : when I click on Vray Frame Buffer after the end of any render 3dsmax goes in error what’s wrong?
I have 3dsmax 2013 and Vray 2.40.04
Can you help me
Thank’s
Daniele
sorry for my bad english :slight_smile:
What kind of error?
I was wrong I mean crash
when render is done if I click on any button on VFB 3dsmax goes in crash
Best Regards
Daniele
Does it happen every time or it appears just randomly ?
Have you tried to reinstall Vray , if not please do it and run the same test again.
If the issue still persist please send us an email to support@chaosgroup.com in order to schedule remote meeting.
Same big problem here…
VRB causes an 3dsmax APPHangB1…!!
Reinstall vray 3.01 does´nt help…switch to direct3d viewport does´t help
merge in new scene..no results…
3dsmax 2014 x64…
..any solutions???
best regards
chris
Does it happen for this scene in particular? If yes, can you send it to us to vray@chaogroup.com so that we can reproduce the problem and fix it?
Also, if you get the 3ds Max CER dialog after the crash, can you send me the latest 3dsmax_minidump.dmp file from your temp folder (type %temp% in Windows Explorer to go there) to vlado@chaosgroup.com - it will tell me what crashed and where.
Hello vlado,
find the bug! There was standard normal map inside a vray proxy… switched to vraynormalmap brings the solution… seems to be a bug, when using standard normal map inside a vray proxy…
Ohh yes, there is that. We need to report it to Autodesk…
