Hello!
I know that the issue of renders coming out with some offsets from the Rhino viewport and Vray framebuffer has been reported. When would the fix be released?
Is there a temporary solution to this issue in the meantime?
Thank you ![]()
Hello!
Thank you ![]()
The developers are still working on that.
Also unfortunately there is no workaround at this point.
Yes, don’t use 2 point perspective,instead use lens shift there is a script floating somewhere on this forum to guess the perfect vertical shift.
The script is called lens shift
Great I will look for it..!
here it is.
-_Runscript (
Call guess_shift()
Sub guess_shift()
Dim view : view = rhino.CurrentView
If Not rhino.IsViewPerspective(view) Then
rhino.Print “can’t calculate vertical shift for orthogonal views”
Exit Sub
End If
Dim cam : cam = rhino.ViewCameraTarget(view)(0)
Dim tar : tar = rhino.ViewCameraTarget(view)(1)
Dim cam_a : cam_a = cam
Dim tar_a : tar_a = tar
cam_a(2) = tar(2)
tar_a(2) = cam(2)
If rhino.Distance(cam, tar_a) = 0 Then Exit Sub
Dim shift:shift = rhino.Distance(cam, cam_a) / rhino.Distance(cam, tar_a)
If cam(2) > tar(2) Then
shift = -shift
End If
rhino.Print shift
End Sub
Thanks Renee.
So, I use this script while in perspective mode, right? Would my viewport be tweaked into a ‘fake’ two point perspective as well? Or just the render result will be in ‘fake’ two point?
yes use it while in perspective mode.No the viewport won’t change.
You have to write the result in the lens shift box in the camera setting,
Thanks. Very interesting to me. I wish I know scripting…!
I wish i could to ![]()
