Hello Vlado,
thank you for your replay. The 3dsmaxcmd lists the generic max commands. We must save the VrayFrameBuffer image. 3dsmaxcmd.exe with *.EXR wildcard saves teh EXR from the standard max save filed. This is mostly black image. I want to batch 1000 max scenes from commandline where each scene should save VrayFB result with my predefined name. (we have 1000 3d product packages where we need to render 4 views in VRay and each view get a custom name as file etc - so it must be automatized).
To illustrate it:
d:\graphics\Autodesk\3ds Max 2015\3dsmaxcmd" -o=“\\3d-io\projects\_maxscript\E1234_perspective.exr” -frames=0 “p:\_maxscript\E1234.max”
saves VRay image frames as Max OpenEXR, in standard max format. This image is mostly useless since we have VRayCamera and VraySettings which needs to be saged as Vray EXR DeepPixel, 32Bit etc.
How can we access this commands from teh 3dsmaxcmd?
Thanks a lot in advance for the help!
best regards
