vray fur directions
Hi, how can i make the hair go in a certain direction? it needs to follow a specific flow.
A brush would be so helpful for vray fur as a feature.
You need the VRayFur Styler. Check docs.
Hi @hermit.crab - I don’t see the styler in the docs. I also need to manipulate my Fur
what is the easiest way to get the fur to react with another surface - like a floor? I have a chair with fur on, and I want the fur to deviate when it hits the floor surface.
vray fur is a bit limited.
For the chair contact what you could try is using the vray distance Tex to Drive any of the fur texture slots (for example length) to get some variance where the chair contacts.
Updated docs page link above. Otherwise, what @mschreck suggested should work.
