Hi all,
We’re having an issue when using VRay Fur. I’ve got a couple of different maps in the Length, Density and Bend Direction slots, if I reload the maps then it renders fine. The issue is when I reopen the scene and render it the fur doesn’t render. The only way to fix is to click Reload on the maps, obviously this means that rendering on the farm won’t work though.
I’ve created a simple scene using the same textures and attached it. It may be that I’m not using the maps correctly in these slots so please advise.
Thanks,
Max
Fur_Problem.zip (737 KB)
