Vray Fur Icon size
Is there a way to lock the size of the Vray Fur Icon in the viewport? is quite annoying that gets constant size in the viewport always.
Thankyou!
That would be great .
As workaround I use “display as box” option under object properties for such cases(vray fur, plane..)
Good idea! M. Max :slight_smile: It IS very irritating :stuck_out_tongue:
You can turn it off via the ‘Icon text’ checkbox in the viewport display rollout of the VRayFur.
didn’t know the display as box trick, helps a lot! Thankyou.
Thanks Aleksandar, but that doesn’t work, what you suggested just hides the icon text, but still the icon always have aconstant size in screen.
would be great to have a “lock icon size” with a size parameter next to it for example.
Okay, now I understand (by icon I thought you meant the text itself)! We already have this request logged in our system (VMAX-7716), I’ll bump it by adding your request as well.
