Vray Fur issue
While it was a great recent update for Vray Fur support, I’ve been dealing with a crash when I live link with a scene that has Vray Furs.
It just shows a black screen and there was a message attached. When I removed all the Vray Fur, it worked fine.
The scene was relatively heavy. I guess it’s a factor that Vantage only supports Vray fur with a limited file size.
I hope Chaos solves this issue soon.
Hi, thanks for posting. At one point you should run out of memory. Please check if this is the case. Are you able to render this scene with V-Ray GPU?
@vladimir_krastev ​
I checked task manager while Vantage was running but I didn’t see Video Ram run out. I have an RTX 5000 with 16GB VRAM. It was only used about half of my VRAM.
I’ve tried V-Ray GPU and it works. Just Vantage is not picking up the render, showing a black screen.
I hope Chaos solves this issue soon.​
Not sure what you mean by “only supports Vray fur with a limited file size”.
We can’t solve the issue unless you send us the scene and steps to reproduce, as currently we don’t know what the issue is.
Greetings,
Vladimir Nedev
Hi thiago_peixoto,
Are you using 2 GPUs? I have tested on a dual GPU setup and cannot reproduce your issue. Can you send us this scene or a similar scene that reproduces this?
Alexander
Im using NVidia 3060 Only on windows 11. Before this I was using 2.3.0 version of vantage and no have issues
Can you send us the scene and the debug log ?
Greetings,
Vladimir Nedev
I forgot to mention that my i7 processor has an integrated video card.
The warnings state that you are using multiple GPUs.
Can you check from Edit → Render Devices… ?
If you could locate the full debug log in %appdata%/Chaos/Vantage/debug_log.txt and attach it here, it will also be helpful.
Greetings,
Vladimir Nedev
