Vray FUR on backside
Is that possible to apply Fur on the backside of the object? for eg, if i am having a plane - with double sided material. Applying fur is displaying on front side only. can we able to apply for back side also ?
Regards,
Gopinath.
VRay Fur is generated only on the front faces. You will need to add a shell to your geometry or make a very thin box. Then you can exclude the thin side faces for the fur generation.
Hello Martin,
Thanks for your reply.
Will try as per your suggestion.
Regards,
Gopinath.
