vray fur related crash
not a real big issue, but is you have a fur object in your scene and want to move the fur from one object to the other and accidentally select a camera instead of geometry, max will crash
max 8 sp3, vray 1.5rc2
i had similar thing …selected fur…then went to mat editor and wanted to load a mat from my mtl library…max crashed
I think this is corrected in rc3.
happened to me 3 times in a row in RC3…
i simply selected the fur object, went to mat editor, clicked on get material fromscene and b4 i was able to apply it it crashed.
but this happened only when i used this procedure. maybe it was max related though i dont know
I was referring to the original problem (picking a camera)… I’ll take a look at the situation you described.
Hey Vlado,
Another vrayfur crash, if you apply a vray fur to an object then apply another vrayfur on top it will close max very quickly.
I can’t get this in RC3… I know it was an issue in RC2 though.
ok, i havent tried it in RC3.
Hmm, I couldn’t get this here on my simple test; does it always happen? Which 3dsmax version?
