I’ve been working on a project with hair using vray fur. I was trying to get a hold of the vray fur styler which I did. There were no instructions on how to install the plugin. I tried simply putting the dlo file into the vray plugins within the max plugins. I’m not sure if this worked as I can’t seem to access it anywhere. Has anyone every used this before? (as a note, I’m using 2011 and the plugin I have is for 2010, does this matter?)
I’m getting an error when starting the program (after putting the files into the vray plugins folder) saying that it failed to initialize and the files are not a valid win 32 app. Is this an error on my part or am I missing something?
I put the 64 bit files into the max 2011 vray plugins folder (which is 64 bit). The files that I have are for max 2010, so I’m assuming they’re not compatible? Is there a version for 2011 yet?
