We?ve run into a problem where if we create a scene with vray fur, vray scatter, and an active vray dirt texture (meaning it is being evaluated at render time) vray crashes and it prints the following error:
// Error: line 1: V-Ray : Exceptio : Rendering region (coordinates of the bucket)
If we hide either the scatter object or the vray fur, or if we disable the vray dirt texture, then it renders. It is only when the 3 are present that it crashes.
We first saw the error in a production scene, but after some research we were able to reproduce the error on any scene, doing the following:
-Create a plane
-Create a cube
-With the plane selected, create a vray fur object
-With the plane selected, create a vray scatter object, and add the cube to the list objects to scatter.
-Create an Extra-Tex render element, and connect a vray dirt texture to it
-hit render
Is this a known bug? Has anyone encountered this or anything similar?
We are using:
-Maya 2016 Ext 1 SP 6
-Vray 3.60.02
-Vray scatter 4.450
Running on windows 7 SP 1
Thanks,
Miguel de los Rios
