I was wondering if someone could help me please?
I am rendering a night time animation and using Vray Glare and Bloom accross the backburner and I would also like to denoise at the end using the standalone denoiser.
I have set the denoiser settings to ‘only generate render elements’ and saving out as an EXR. so all the required denoise elements are combined one file
I am rendering accross the back burner the glare and bloom is being applied at the end of every frame as it should but when I open up the saved EXR the glare is being saved. In the glare settings I have selected both ‘image + Render element’
Why is the glare not showing in the EXR? Is it posible to denoiser frames with Glare applied? What is the correct way of rendering and animation with glare/boom and then denoising?
Thank you very much,
Kind Regards,
Will
