Hi Konstantin
I don’t really have a clue but sometimes is imposible to finish a render
I use 2 2080 ti with nvlink 1 is for the 4k monitor. I use both for rendering bacause the pool memory. But 1 gpu suffers a Lot for this…
This is very stressfull…
I can’t upload the image bigger because it only acept 2.0 mb is really small.
As You can see with vray 5 gpu happens the same some buckets get stuck, 6 buckets per gpu stuck for more than 1 hour Or maybe more.
Before You bring clouds and this kind of fantasy please fix that problem.
Vray 2 sided material with stone wall with displaccement suffers a Lot
I’m tired of your software… vray gpu is very unstable.
I don’t want clouds and faster light cache and out of core for vray 6 i just want to render my spaces as i use to do with vray cpu.
Very frustrating using vray gpu.
Im going to keep this heavy scenes and i’m going to try with vray 6 this proyects, if i find again this issues i’m not going to update to vray 6.
Vray gpu RTX suffers a Lot and probably this is a Bug, since im using 2d displacement.
Sometimes i love vray gpu and sometimes i hate vray gpu…Jesús Cristh… Please make the software as Stable as it can be.
Vray gpu is not the same as vray… Really needs a Big Big update… I don’t want clouds i just want to render as it should be…
Again problems with vray gpu…ohhh god why i always have to suffer with vray gpu??
Please fix the RTX engine for vray gpu!!! Sometimes i just loose My time… Because just 6 buckets get stuck for hours… We need a solution for that!!!Not fantasy like clouds!!!
