Vray gpu 6 compressed textures mode (vram and speed)
Hi Muhhamed
I would like to ask you about the new mode
How big is the speed with this new approach and what kind of diference we should see about the vram.
For example if my proyect use 18 gb of vram for textures how big is the save of vram with the new approach compressed textures?
Works for every texture?
Just for 4k textures or even 8k textures?
I believe there should be a video about that
So we see the compressed textures mode in action
How do i know how does it works?
Right now this is only for vray for 3d max, but i really hope to see this feature for vray for sketchup
Thanks in advance
You can test it yourself. Render a plane with a high-res texture with Full Size and Compressed texture modes and look at the Memory Tracking tab in the VFB2 Stats.
Yes. Tested it with a 1 MB texture and it is compressed too.
I dont use vray for 3d max neither 3d max, just vray for sketchup.
So i dont have right now this tool available for vray 6 gpu
First vray for 3d max
Second vray for maya
third vray for sketchup
So probably is coming first for maya and is not even ready for vray for maya
That is why i would like to see this new function in action hermit.crab
I dont have this tool yet for vray for sketchup
Also i use a lot vray fur so if i can turn on 7 tapestries with vray fur that is going to be great.
A lot of times i can only turn on 2 or 3 tapestries because textures always takes a lot of vram
I hope i made clear
The last question is there any speed with compressed textures mode hermit.crab or is just the vram???
For interiors vray gpu sometimes is very slow, even without fog and depth of field
Imagine using both vray gpu can take a lot of hours to complete a render
It will be eventually.
This is highly dependent on the workstation/farm’s capabilities and the demands of the rendered scene. The feature will surely help, though.
I presume it will have an increase in loading speed, even though the compression will take some time too.
