Vray GPU Displacement error with PhoenixFD
I get a weird error with Vray GPU and phoenixFD when using displacement.
I hae fluid simulation done in vray and want to render it with VrayGPU. My material is having a displacement to add some details to the fluid texture.
When rendering this as a squence, I get weird meshes on some frames.. basicly only the first frame I render is perfect, all other have more or less issue.
When I render these frames one by one, each as a single frame, they are perfectly OK.
They render fine as well, when using Vray 5 (CPU).
Attached is an image where you see the problem…
So Vray GPU has issue when rendering phoenixFD with displacment. Is this a know bug or do I need to adjust something ?
I happy for any help :slight_smile:
Sorry for the late reply. Could you send a scene via the contact form so we can take a look? Mention me and include a link to this thread in the message.
