Trying to render a vray volume grid using vray gpu 7 stable update 3 DR1. It will always render 1 frame, then on the next frame get halfway through crash the frame buffer, and then max. Any ideas? Error is:
[16:40:54.089] Error : C:\CI\cgrepo\vraysdk\samples\vray_plugins\rt_priva te\rt_opencl_(2943) : CUDA error 700
Rendering just the grid and two matte objects inside the grids volume. Grid points to a local vdb file.
Attached is the max minidump.
3dsmax_minidump.dmp.zip (2.21 MB)
Thank you. We will check as quickly as possible.
@nickolay411 Could you share your scene? I wasn’t able to replicate the crash in a fresh scene. Thanks!
Hi sorry, I didn’t realize there was a response. I cannot share the scene but can you look at this 3dsmax crash mini dump? I am still getting crashes rendering a vray volume grid with a .vdb loaded in.
I am running the recommende studio driver, latest release of vray and Max 2026
If the minidump doesn’t help I might be able to send a few frames of the cache in a scene. Please let me know. I’ve been battling these crashes for a few months now. Across drivers and releases.
3dsmax_minidump.dmp.zip (2.4 MB)
