VRAY GPU // .exr file extension automatically changes to .vrimg
A very basic issue—not serious at all, but incredibly annoying over time (and a source of errors and frustration).
The .exr save file type automatically changes to .vrimg (nearly?) every time we enter the V-Ray Raw Image File menu to set a new output path and/or a new file name.
So you have to manually choose the output to .exr format every time you render a new output regarless the previous format selected from the same file. Otherwise, the entire image series automatically saves in the wrong format.
I can’t pinpoint exactly when this started happening at the studio, but I’d guess it’s been about six months.
I suspect this might be caused by several different programs (3ds Max, V-Ray, RenderFlow, etc.), but I wanted to know if we’re the only ones experiencing this issue or if others have already encountered this problem.
It happen on all our computer at the studio, regarless the hardware (software is the same everywhere)
Thanks for your time and answer,
Nicolas
W10
3Dsmax 2025.3.4
Vray GPU 72008
RenderFlow 1.2.6 (our render manager)
Something similar was reported recently. It happens on scene restart. There’s no issue if you don’t change the name (format says .vrimg, but the filename has the .exr extension), but setting a new one, indeed, requires a format change. I’ll log it.
EDIT: Logged as (VMAX-15482).
