Do filter type and filter blur for bitmaps work for vray 5.1 gpu in sketchup?, and if it doesnt works when Will we have this option available…??How important is the sharp isotropic??? and what kind of benefits can we get when this would come available??
I remember mipmap, summed área and the last and probably the Best of 3… sharp isotropic that came with vray next update 2 hotfix 2
Filter type and blur value don’t work for Vray GPU at the mean time, the GPU engine uses its own special filtering for bitmaps automatically. It does a good job on bump mapping see below(the details and text on tire are bump mapping)
We have plans for this yes, it is on our to-do list
On the CPU engine this new filtering mode does a better job in keeping the details of your textures with minimal blurring. Check out this discussion here
I think this is the new mode mentioned in Vlado’s post, I use it personally for all my textures.
And you should only reduce filter blur when needed, don’t use it on all your bitmaps. I personally use 0.2 for bump mapping/normal mapping like what Vlado recommends and I leave it at defaults for everything else (except for very specific cases)
In vray bitmaps as default appears sharp isotropic, should i leave it as it is by default or select none???, Also as a feedback in vray for sketchup mipmap and summed área don’t work really well they are very old filters, but sharp isotropic can be very helpfull, and the filter blur it would be great for bumps maps and normal maps, and sometimes for very, very crisp difusse maps
Thanks again for your help Muhammed
Using Sharp Isotropic or None will have no effect on GPU rendering, but I guess you can leave it to Sharp Isotropic(it works best for CPU rendering as discussed above)
Yup, it is all true for Vray(not for Vray GPU). I do stick to Sharp Isotropic myself for all my bitmaps (I guess the rest are in place for legacy purposes, or special use cases)
