Vray GPU NEXT 1.1: Copy to clipboard and GPU Stats problem
Hi guys,
I’ve a problem.
If you set Vray GPU and you enable the VFB GPU Stats, when you use the “Copy to clipboard” button and paste it somewhere, the GPU Stats will be saved on the image.
Is it designed like this? I think that it’s more a priority to have just the image copied.
What do you think?
I’ll make a note of it in the bug tracker. Thanks for the feedback.
