Hi!
I’ve tried rendering a TyFlow object with a modifier on top of it and with the VrayGPU the modifier gets discarded at rendertime. VrayCPU renders as it should with the modifier modifying the TyFlow geometry.
Is this a bug?
Is there a workaround other than using a TyMesher to reference TyFlow geometry?
Pls help!
Thanks for the report. I’ve logged it (internal bug-tracker id: VMAX-11256) for developer investigation. For now, the tyMesher method seems to work fine and could be used as a workaround.
