so do you know if it will be available in an EDU build? i’m confused why the edu build wouldnt get what seems like such an important feature.
thanks ![]()
thanks ![]()
Hi Guys
This conversation should have been made in the beta forum to avoid confusions. I thought that the current released build had wrapper material. I downloaded and installed the educational version and the wrapper material is not there. We don’t have any limitation in term of features on the EDU version, so, yes, we will have the wrapper material and the screen environment mode in the educational version. We are pretty close to release a new build. So please have a little bit of more patience.
Fernando
PERFECT! that clears up all confusion and sorry this thread got off track with beta stuff!!
thanks a lot fernando!
where is the beta forum?
To get access to the VFR beta you can send a request to support@chaosgroup.com
After the video Pedro did, I decided to give another try to see if wrapper material can do the job for me
Unfortunately Wrapper material it is not yet working as I expected. I know the ground plane should be exactly around the shadow but this takes time to be determined, also the shape of the shadow never goes rectangular..
Do you see anything I could improve using wrapper material? Did you get better results on your projects?
thanks
You may try to reduce the receive GI option, I guess around 0.2. I would like to have your scene to look at it and give you a better solution.
Here is my email: fernando.rentas@usa.chaosgroup.com
It is not a big deal, but my name is Fernando, not Pedro.![]()
Best
I’m so sorry. I know you are Fernando.. was such a warm day at the office (honestly) ![]()
thanks for your reply, I will play around with your suggestion
I got it! Wrapper mat perfectly working!Click image for larger version.
Fernando, thank you again! The receive GI was the problem, also I have set my shadow brightness to <1Cheers and happy weekend
You are very welcome!
Hello
Where is the nightly build? I have latest version in Rhino 5 and cant find the wrapper material
Best ask at the beta forum.
witch one ? the one we were on before 1.5?
Yes, it’s a closed forum for the beta testers.
