Hi
Im doing some tests and the fur with vray fur and with 2 sided material as a material for the fur looks fine.
Also with 2 sided material the hair looks like a tube, not flat which is the correct form of the rugs.
With the hair material the strands looks like a grass it is total plain.
What are the difference using both with vray fur???
If you want to do a close up render the 2 sided material looks better than the hair.
Did vray team really look at this?
