I am in the process of trying to setup a stylized fur shading in maya vray with hair next material.
Unfortunately I struggel to keep the color of the fur close enough to the initial design (different very extremely vivid colors) while keeping it realistic at the same time.
->The vray hair material renders much darker than the underlying vray material
Also when i set Diffuse to 1 with my diffuse texture plugged in the colors match the texture color obviously but i completely loose the realism.
So i have to reduce diffuse but while doing this the color darkens more…
Also wondering what the difference between dye and diffuse channel is and what would work better for a stylized fur shading.
I guess i am trying to use the hair material to render a way its not intended to…
any hints appreciated
