vray hdri and curve editor
Anyone know how to access the multiplier for hdri material in the curve editor? I can only see 4 options for it and none are the multiplier.
For Vray the multiplier should be a spinner in the material editor when you copied HDRI from the environment slot (I forget which order tho it should be there.) I hope that answers your question.
I want to assign a controller to it, such as a noise float.
Tricky. I wonder if you would need to load up splutterfish’s hdri loader within vray in order to do that.
good question. is their hdri loader still compatible with vray? will have to see if I still have it on my harddrive somewhere
Yes it does, splutterfish hdri loared works just fine. As I only got the basic version of Vray, this tool is soo usefull, and it works well with the sphere technique over the environment one, wich is way more versatile
