Vray Help Index and 1.09 - 1.45 compatibility question
just in looking at the current help index (when I log in),
question: Is there a way of downloading the complete help index in one go as oppoesed to going to each individual page?
I will be requesting Auth for 1.45 today, if I need to load a 1.45 scene onto a pc (mates render farm) that uses 1.09 is there any compatibility issues? Appreciate it is a basic question but we are not as familiar with Vray as we are with Brazil, Yet!!!
thanks,
Tom
here are things you will need to check. if your using QMC for secondary bounces then you might wanna look for the rollout for it and drop it from 50 to something like 8. (under the QMC GI section not the QMC sampler section) also you will want to go into materials and change the subdiv on your glossies. 10 or 12 is good 8 is default now. If you had previously used the trick of putting opacity maps in refraction slot then you can change that to the opacity slot which is in the newer versions. thats all i can think of for now
grand, thanks for that,
oh tnx tnx!!! :lol:
