VRay IES lights and viewport
I’ve just discovered a weird limitation of VRay IES lights, when it comes to viewport feedback of the IES profile web. Please check the attached preview, left is std 3dsmax IES, right is VRay one.
Could that be fixed please ?
Thanks,
Regards.
It should be fixed already for V-Ray 2.0, if you have “enable hardware shading” turned on for the VRayIES light.
Oh ok, I haven’t downloaded & installed v2.0, can’t wait to check that :slight_smile:
Thanks a lot for your quick answer.
Regards.
Thats cool. I didnt even realise you could preview vray IES lights in the viewport…cool !
Eheh - glad you discovered it :slight_smile: that’s pretty comfortable when it comes to lights placement !
Cheers.
Hello :slight_smile:
I don’t know if I do something wrong, but that still doesn’t work (using viewport shading on Best / SM3.0)… IES lighting preview still doesn’t match :frowning:
Thanks !
