That’s the shape for the distribution, it doesn’t have a scale : notice that when you zoom in and out the size for it stays the same.
It’s because it only contains directions and intensities.
If you somehow exported that and emitted from it you’d get radically different results.
It’s being worked on.
Regardless, we’re not yet thinking of making the changes public, as the *general* usefulness is exceptionally dubious.
What exactly would be your interest in having the shapes as meshes?
The dimensions are returned exactly as per the shape standards of the IES commitee, so they may be negative in one or more dimensions (that’s how the shape type is defined.).
Care should be taken to use the absolute value for these while building the meshes.
If an override shape is used, then the standard methods to gather the type and dimensions should be used (f.e. .shape and the .height, .width, .length and .diameter properties).
