do you guys use the physical camera? if so do you use realistic exposure-settings? When you create a new vray physical camera the exposure is fine for outdoor scenes with vray sun/sky, but way too dark for say an indoor scene lit with ies-lights…
I rarely use ies-lights myself, so i dont know if this is your problem… just a thought.
I run physical camera and adjust the exposure to suit an internal render. Not sure what setting the light is on, I just turned it up untill I got the effect I was looking for. But the whiteout of geometry is difficult to work with, so I end up switching the lights off to work… and that cant be right
im using ies light in a current project, the scene is in meters, phisical cam setting ( iso 8oo shuter speed 5 fstop 3.5" as u would set up a camera when shooting at night & the result im getting are very realistic without adjusting any of the IES power
