Any ies file I try loading into a VrayIES light throws a bunch of errors regarding “Syntax error:unexpected end of file”, “Syntax error: At least two vertical angles must be specified (-1)” and “The photometric web file, (path to my ies file), is not valid”.
These ies files obviously worked before, but i have not used them since upgrading to vray 3.10.02.
Very strange. I’ve never had this error and I’ve tried IES files that are 8-10 years old. Seems like an isolated case to me. Are completely sure you used these before and worked fine? Did you tried other IES files, maybe some new ones to see what happens?
I meant the IES files. All of these work fine for me in a quick test (a plane and a VRayIES light) with a nightly build. I will try the official builds next. Which 3ds Max version are you using?
Ok.
Besides from this being incredibly irritating, the fact that I can not “clear” the VRayIESLight’s map slot where the IES file was loaded really gets me angry.
Why cant I right-click the slot and clear/copy/paste it like with other stuff in max?
Is there a maxscript-way to remove any IES files from the selected lights?
You can imagine Backburner is happy trying to load and render a file with 6 of these error popups. DR for some reason seems to at least render them correctly even if vray complains on loading the file.
I tried your IES files and they seemed to work fine both as vray IES and photometric web. (Though photometric web looked really bad compared to the vrayies.) Maybe you just need to reinstall max or vray…
Well trying to recreate this problem doesn’t work, which should be a good thing, but makes me very confused.
The strangest part is that after stripping the ies files from their respective lights, and saving, I still get one of these errors when reloading the scene, though not 8 as before. There are no ies files loaded in the asset tracker. I am going mad.
OK…so things are getting even more strange.
While preparing a stripped down file for you guys, I saved the ies lights and fixtures out to their own file, and started from there. At one point I checked the asset tracker and saw that the file was still reading in massive amounts of textures, and I figured this was the slate editor not having been cleaned up. I proceed to delete all the active view-tabs and resave and close max, reopening the file.
At this point I have not done anything with the lights. Upon reopening, the error messages are gone. The ies lights are still reading the ies files from the server.
I have no idea what might have caused this, as one can not view ies files in the material editor afaik.
I could archive the whole thing without cleaning, but its quite large and usees railclone and forestpack extensively in case that would be a problem.
Do you want to try this massive file?
