Hi!
The Vray image file node is not listing all available color spaces under the OCIO tab / In and out color spaces anymore on creation. There is only “no entries” in those option menus.
This is an issue for us because we have expressions setting up the correct color spaces based on texture naming rules. Now those expressions are not working.
Flicking the Configuration Source option menu back and forth refreshes the interface and populate the lists, if that helps you narrow the problem down.
Using H18 and vray ‘43003"’, ‘5e8c87f’
Cheers!
could this be looked into as fast as possible, giving us some issues
Regards Alexis
Tested now with vray “43003”, “bd3b8dc” and still same issue.
Also found another issue with the vray image file and ocio.
The intensity output of the node is not working correctly with the ocio enabled. When connected to the reflect_glossiness input of the vray material the glossiness is set to 1 allover.
Disabling ocio on the texture node makes the texture work again. We need color management via ocio in our pipeline though.
Would really need a fix for this as soon as possible.
Cheers!
Hi guys, this one is fixed in last nightly build.
edit:
float output slots are not yet fixed !
