It seems lately that DR nodes returning buckets during imap calculation are sometimes severely compressed (or what ever is going on). This used to be only slightly, but now I’m having serious doubts as to whether or not the dr nodes are not picking up hdri domes and stuff that usually makes buckets look like crap. I seem to remember Vlado mentioning that the prepass-buckets are compressed now, but this is maybe a bit over the top? Could we get an option or something? How much network bandwidth are we actually saving by sending these seemingly 4 bit coloured buckets as opposed to before?
Oh… forgot to add:
When working at home and running DR over vpn (I only do this on manageable scenes), The DR buckets returned during pre-pass are even worse. They look like diagonal white stripes. Not sure if this is related or even by design, but I thought it could be relevant.
Well I do, but it uses massive resources from the network here. Proxies and an Exr for a domelight. It also relies heavily on ForestPack pro and RailClone (my new favourite plugin), so unless you have them, the scene will be mostly empty. After I’m finished I can probably use the tool for RailClone that converts it to instanced dum-objects.
But as far as the cross-hatch looking buckets over the internet through vpn, Im not sure if this will help.
From what I can see, this happens even in the background, so you can probably just delete all the geometry from the scene…
But as far as the cross-hatch looking buckets over the internet through vpn, Im not sure if this will help.Yeah, that one is odd. Do you have a screengrab for it too?
hmm…well I kinda thought you would not see the compression artefacts if they were all black.
I’ll make a file with some content later this evening and post a link.
this happens to me too very often…almost every render in larger size.
We have over 90 buckets and sometimes i also wonder whats gonna come out in the render because of those differences.
If this makes rendering faster then i understand but it shoudl be mentioned somethere in the log or there shoudl be a checkbox to use compression or not at the cost of some rendertime.
This has been happening in our scenes for past year…always being on the latest version (no nightlies)
Just my 2 cents in this issue.
Ok. so I just finished making a version of this scene for you Vlado, and decided to test render it before posting…guess what…no strange buckets.
So I will need to find whatever was the reason…hoping its the exr loaded in the domelight that I removed, so give me a sec.
Great to hear. To emphasize, some compression or whatever you had going is fine, but it sometimes got so bad that i looked like faulty buckets.
Sorry about not making the test file for the issue I had at home over VPN. Been a bit busy.
Hi Sir,
Is this issue solved…
I am also getting some what this kind of a problem
Please could some one help me…
This happens only when I use my render slaves systems…
Thanks alot
I get those often, without warning, on random projects. It can go on for a long time, and then stop, as fast as it started. I tried restarting, rebooting.., but nothing seems to work, but it’ll stop by itself.
Sir Thanks
done all…
downloaded the latest built again and installed but same issues still there.
So for the moment just doing individual rendering.
