Thank you, that article was the basis from which I started learning how Vray works. By the way I remember interacting with you on another forum about CG, it’s a small world (your calculator is great).
Thank you, this cleared a lot, it’s great to hear from the developers themselves.
So in other words Adaptive DMC was developed to render blurry effects-heavy scenes without wasting away enormous quantities of rays. I started using Vray in university and now that my career is about to start I decided to keep using it and buy a licence for myself. As I said I read a lot about the software, both the official help files and third-party materials, but I still can’t get a couple of points:
1-When does the Image Sampler add antialiasing? I assume that the it has to add it as the very last stage of the rendering process, when the image is already complete. At the same time, the Image Sampler traces the primary rays, and that’s the very first step in the rendering process; but if the sampler would calculate the antialias at that moment, the secondary effects (GI, reflections, etc) would be left without antialiasing because they still haven’t been calculated. I theorized that the Image Sampler works in two steps: it first renders a very basic “base picture”, tracing 1 ray per pixel (like in the old raycasting); from that base picture it calculates the blurry effects, adding GI, area shadows, refractions, etc with secondary rays; as a final step, it retraces primary rays according to the Image Sampler settings, and add antialiasing on top of everything. Am I correct in this assumption?
2-The Adaptive Subdivision sampler uses Min/Max rate instead of Min/Max Subdivs; I read contrasting information about what’s the real number of samples here. I think it uses the infinite series 1, 4, 16, 64, 256, etc as in:
rate of 0: 1 sample for pixel
rate of 2: 4 samples for pixel
rate of 3: 16 samples for pixel
rate of 4: 64 samples for pixel
rate of 5: 256 samples for pixel
rate of -5: 1 sample for 256 pixels
Thank you for your time.
