vray instancer and alembic particles
Hi I bumped into an issue with instancer togehter with alembic particles. It seems instanger ignores velocity or width, it even had problem with orientation but we manage to overcome this.Check alembic in attachments.
test.zip (7.73 MB)
Have you exported the velocity data when making this Alembic? To get the correct width, set the Particles’ “Scale mode” (VRayProxy > Proxy params> Particles) to Radius only or Scale*Radius. Helpful info here.
Aah I completely forget about Scale*Radius option but however velocity is there and it doesnt work as expected. Some particles are moving frame to frame and with enabled motion bluer they appear in midframes for no reason.
Moblur looks fine to me. Could you share a screenshot?
Its maybe not related to velocity but how instancer scatter objets on particles. If you take a look for example on frame 1365 those teapots are flying from world zero to threis “spawn” position instead jus popping there. We had to spawn all particles on frame 0 because dynamic particled dont work with instancer (or we did something wrong again)
I saw what you mean, but this seems like an issue in the alembic itself (happens without instancer, too; happens in viewport / when previewing spheres). Try exporting the .abc animation on full frames.
EDIT: Actually, I can only get motion blur on the VRayProxy default spheres. I’m not sure if the VRayInstancer can inherit the velocity data (though it works for width); I’ll ask the devs.
it is without subframes (full frames) but alembic for some reason interpolates between frames and I dont know why avoid this
You are right velocity indeed doesnt work with instancer :frowning: But at least I found solution for “subframes” issue. Alembic for some reason interpolate in subframes even when only full frames are saved, so only solution which works was to force as much sumframes possible to negate this linear interpolation, in my case 10 subframes was enought. Strange…
Did you find any info about motion blur not working with instancer?
Not yet. I sent a sample scene to Vlado, and he told me he’d look at it, but I’m guessing he’s been busy. I’ll see if some other dev can take a look.
Confirmed - VRayInstancer does not take into account the alembic particle velocity channel when reading particles from VRayProxy - and logged (VMAX-15219).
