Vray instancer problem
I am trying to use Vray instancer with PHX foam to get it to render in Vray4 beta3 GPU… it is producing tons or error but sometimes renders anyway.
It has to do with PHX coz when I use PFlow it doesnt produce errors, although the render % doesn’t work.
Nope, this is not implemented, sorry.
Hopefully in the not so distant future…
OK, tried installing back 3.6, same problems here just a cleaner 1 error and end before starting…
I really need to be able to render the foam, the liquid looks out of scale without it.
Export of particles is also not really working as Prt is fine but limited to use with krakatoa, which I don’t have…
OK, I see there is a PRT reader, I will see what I can do with that…
