hello
I got problem with this and only solution how to correct it is ,escape from viz ( in my case ) unplug dongle and than plug in back.
Can you help me with this strange thing ?
hello
Which V-Ray version is this?
2 vlado :
hi
it is a 1.5 sp1 for max8 86x, but iam using it at viz 2006 sp1
Things you can try is to plug the dongle into a different USB port, and also install the latest WIBU drivers from http://wibu.com/download\_user.php?lang=en and see if this works.
2 vlado :
thanks for help, it seems that change of usb port helped out ![]()
2 all :
well i discovered problem,is it in my mobo especially usb ports , mobo dont giving right power to the devices through the usb ports , i found it when i plug in usb drive and OS dont find it.
