Vray License (Home + Office)
Some of us take work home weather we like to or not. Does Vray allow for home and office installation since a single license can be used for up to 10 workstations?
Some confusion there it seems 8) It supports up to 10 DR rendernodes, not 10 installations…But the home/office is usually possible as you will always only use the one or the other :stuck_out_tongue:
So you can either get the license via VPN, or when the dongles are out via http if i understood that part right.
Thorsten
“Soooooon”, VRay 1.5 will be released. Then you will have a USB-dongle. This should allow you to work wherever you want as long as you have the dongle with you.
It was also said the dongle´s lic-server allows grabbing a lic via http…so maybe dont even need to take it home if you got inet :slight_smile:
It would be best to write to vray@chaosgroup.com and explain the situation; typically it is not a problem for us to give you a second license for home use.
uhm, i tried lately to ask this question, but no answer :frowning: sniff…
