I am doing some test runs on a scene. set up a camera sequence. and rendered it off. but all the interior lights render with a bounding box for the light source. how do i disable the bounding box of the light source in the rendering. I can not find a toggle in the program to activate or deactivate this issue. is it just a bug?
I closed vantage and max crashed so i assume it must have been a glitch. i restarted the file, opened vantage and linked them, set up a new sequence and it appears to be rendering fine now. just would like to know what caused the issue.
Can you show us how this bounding box looked ?
It could have been the light gizmos - they show up when you have one of the select/translate/rotate/scale tools active.
Greetings,
Vladimir Nedev
should gizmos be able to render? I thought that would be an interface only feature.
How did you render out the image ? I think they are disabled for some modes but not others.
Greetings,
Vladimir Nedev
tools - render high quality sequence
saved as an MP4
