Vray light invisible but reflected
Hello, I can’t understand why all the vray lights in my scene are reflected also if they are invisible…
thank-you for your suggestions
Disable the “Affect specular” option in the Vray light rollout.
once again my wish:
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=16743&highlight=
:slight_smile:
Thank-you Clifton, but I need specular!
I can’t remember this problem on older vray versions…
Well, you don’t have to disable it if you don’t want to, but if you don’t want to see reflections of your Vray lights, you need to.
Specular is the reflection of the light anyway.
So by unticking it of course it will disappear.
Try using a vraylightmtl on a plane and then you can tell it not to be visible to reflections and it still should work for specular.
