VRay Light invisible, or not.
I currently have a scene (buildings) that I am trying to illuminate the interiors with vray sphere lights within various rooms, and I have “invisible” checked on all of the lights, however they are still very much visible through the glass.
How would I go about making them invisible? I’m ending up with large glowing spheres in each room! :stuck_out_tongue:
Invisible option make the light not visible through camera rays - but the reflections of the light will be visible , so you have to also turn off affect reflection from the light properties.
Presumably that will make the light invisible in all reflections then? It’s a shame, because just outside the window it’s creating some lovely reflections on some cladding. :frowning:
It’s not what you asked but depending of the height of the building and if you want nice lighting… I used before several boxes, after that I attached them ( one object) and apply random material Id by elements… The material for the object would by a multiobject material with different vraylight mat intensities, colors, on/off, etc.
Fernando
maybe you could try excluding the window glass from the V-Ray light? (I have not tried that yet.)
It’s a good idea, but the building is too small to warrant that, it just wouldn’t look right on anything other than a large building/skyscraper.
Good idea. Will give it a try.
