Vray Light Material and MASH issue
Pretty glaring problem (pun intended). If you have multiple objects in a group with various Vray materials, including one with a Vray light Material, as soon as you turn that group in to a MASH object, Vray complains it turned off the Light material for a shape with multiple materials. I know I can either separate the MASH mesh, which is a bad idea, or spend the time to break out the Light meshes into their own group and replicate the placement of the Light Mesh MASH object to match the other MASH object. Wasn’t sure if there was a better solution. I’ll post this on Autodesk too.
When there’s multiple materials on the same object, the direct illumination for the lightMtl is disabled. It’s a limitation that we currently have.
