VRay Light Material - Cut Off
I’m facing a strange issue with VRay light material reflections on other objects.
As long as Direct Illumination is on, with Cut Off 0.001, reflection is cut … putting it to 0.0 solves the problem, but render time obviously increases. Setting Direct Illumination off solves the problem as well, but I need to keep it on, so it’s not a solution ! Am I missing something ?
Any advice would be greatly appreciated :slight_smile:
Thanks in advance.
Regards.
Anyone, please ?
I’m facing this problem pretty regularly …
It is somewhat normal; the only way to solve it for the time being is to reduce the cutoff.
Ok, thks for the information, Vlado :wink:
Regards.
