Vray light material illuminating smoke
Can I use a light material on objects to illuminate the smoke from a Phoenix grid? All tests so far point to this not working.
Seems to be working in here. Do you have GI enabled? What version of V-Ray are you using?
Can you show us what settings are you using?
Thanks!
it turned out to be an issue with tyFlow not interfacing with Phoenix - I stuck a light material sphere in the smoke and it worked. Using tyFlow or tyCaches would not work.
Can you send over the scene so we can take a look?
Thank you!
Tyson Ibelle has acknowledged the bug in the interface and should be fixed in the next release of tyFlow
Great, that’s good to know. Thanks!
