This may have been asked before but either the search engine is not optimal or I’m just no good at using it, which is why I have to ask. (again?)
What value does the multiplier of the light material represent? Is it in watts as with the vray light, normalise on/off?
I have to do some (fairly realistic) studies/representations of 25 watts LEDs in action.
thanks in advance..
cheers,
K.
vlado
July 20, 2006, 2:52pm
2
If you have the lumens for the self-illuminating object (e.g. 1700 lm for a 100-watt bulb) you need to divide this by the surface area in meters (use the Measure utility for this), and you’ll get the multiplier for the material.
alright, thank you very much..
cheers,
Karsten
If I am using Feet and inches (system unit = 1inch) do I need to convert the surface area to square meters in the calculation?
thanks
yes.
nikki Candelero
candles
Thanks Nikki,
I made candle flames that are about .002 sq meters which, unintentionally, calced out to be about 1 candella/mult of 40. of course!
I dont know if this is in the manual. but it should be there…
-Tom
