Do not know why every time when I increase the light value above 1, the lens effects go weird, anyway to solve it?
You can increase the Lens effectsâ Threshold value to diminish the effect, however, Iâm not sure if the behavior in this particular scenario is correct. Could you send the scene via the contact form so we can take a look? Address it to me in the subject and post a link to this thread in the message.
Hi, after spent a day with turning on and off objects in the scene, I have solved the problem.
It causes by a standard blend material on a 3d object, I switch the material to VRayBlendMtl, it works perfectly now.
I have another question, every time when I stop render and start render again, the light mix setting will switch back to 1, is this normal?
If youâve added another light between the renders, the values will restart. The recommended workflow is Render with LightMix > Make Adjustments > To Scene > Render.
Noted with thanks.
What I do is save the lightmix, so that when Iâm tweaking I can easily load in/out different setups.
In an ongoing project, a series of close-ups with very different settings for each, I do not want to send those
changes to the scene, as it results in me having many separate scenes.
So whilst it isnât the ârecommendedâ workflow it is in many circumstances the âidealâ workflow and imo should be expanded to work more like this
and include other lighting types such as unique self illumination entries ![]()
In my example I have one âmotherâ scene with 10 saved lightmixes, saving me an enormous amount of time, especially
when they return to make iterative changes.
Would it help if the LM created scene states for the changed entities when the changes were sent to the scene?
Those would then be able to be rendered with batch, while remaining a single scene file.
I think, using my example, that that would just create an extra step, so I would avoid that as itâs actually itâs pretty much fine as it isâŚjust not what Iâd advise to be the ârecommendedâ use.
Basically my opinion is to keep it as it is - with the ability to save mixes to use as in my example, or to send the changes to scene if one needs - and if possible
extend its functionality (the only thing currently I see as missing) to include entries for unique self illumination materials, if that is possible.
If not then cool, itâs still a great boon to us all as it is ![]()
Eh, there is a logical loop i canât find the way out of:
If you *just* save the mixes, then you lose the connection with the scene in potentially irreparable ways (i.e. the saved mixes become useless.).
Consider this: white light, make an LM change so itâs blue.
Save the LM mix to disk.
Save the LM changes to scene.
Now the saved mix is useless for that scene, as itâd apply a blue cast to a -now- blue light.
Analogous for multipliers: thereâs the very real chance to apply mixes twice (which isnât useless, but rather dangerous), as there is no correlation left between the saved mixes and the state of the contents of the scene.
In a one-user scenario, with a tidy, strictly controlled user, this is a minor issue.
Multi-user, bigger pipelines, or slightly more rushed work, this can become a nuisance quickly.
However, if the LM (optionally) saved scene states (ideally with some naming best practice, tied to the mixes saved on disk ) then one would know to always go back to the original scene state (the example light would then go back to the original multiplier and color), and *then* load a saved mix, or simply load the corresponding scene state to get results directly in rendering.
Getting the results into the scene *asap* is the suggested workflow because of noise levels: play just with the LM, and as you double a lightâs intensity, its noise contribution also doubles.
The *only* way to not get that is to use the adaptive sampler during a render of the light with doubled energy.
Notice this is a standard compositing tenant: Iâd often render some scene one or two stops brighter to allow Compositors the post-exposure latitude without exceeding the necessary noise levels.
As for individual self-illum materials, i doubt thatâs practical due to their usual average count, often much bigger than that of lights.
However, you could get places with LPEs, as you can select specific materials and nodesâ contributions, and composite that with the results of the rest of the LightMix.
Ah ok, Iâll explain my example case.
I have a scene with a product with various coloured internal lighting. I have the main scene that I need both a main shot from, as well as multiple close up shots.
So, multiple camera views, each with a slightly different lighting setup and whatever other change to get the best shot.
For each camera view I tweak the lightmix and save that for each specific view.
In that way I can make scene-global changes, yet have a consistent and camera-specific lightmix for each view as I iterate based on feedback.
This is useful in all sorts of ways but mainly, again in this specific case, to adjust the light bleed onto other materials or additively colour the end shot, or to adjust the lens effectsâŚall in a non-destructive way, as itâs only a lightmix and not in the scene.
It has saved me from a total nightmare in this case, as they seem incapable of making up their minds.
I completely understand about the noise levels and have experienced that (I canât find the post right now but itâs about my range rover scene where I was asking explicitly about that noise thing).
So I now know to avoid such extreme tweaks to the original lighting as it can royally fuck up my end result
That was in the first days of using it however ![]()
Having it linked to scene states is a great addition for sure, as it would no doubt come in handy.
The self illuminated thingâŚyeah I thought that may be a big ask. In my mind they constitute âlightingâ but itâs fineâŚI can compensate for that lack.
Thanks for the LPE pointerâŚwill probably avoid that for the moment but good to know.
Yeah, itâs as I âfearedâ: the VFB2 is turning into a mini-nuke eheh.
We hear you, that case *is* common enough, but currently has the outlined pitfalls.
Not simple to work around of, given itâs all live with a 3d scene it depends on, but then simple is generally boring. XD
âŚa sort of âtactical nukeâ really ![]()
Anyway, it wasnât my idea to create a renderer that everyone seems to like and want more from ![]()
Mission-creep is unavoidable. Itâs made my life wonderfully simpler, so, much applauseâŚbut get on and
make it even better you slackers! ![]()
Thank you for good tips.
Do you mean use LM with scene state, havenât try it befoe, any tutorials?
It is just a possible idea for future updates @jackieteh , so it does not exist right now as an option ![]()
