I?ve got the following problem:
- start Max 2018.4 / Vray 3.60.04
- open scene (11-s2-1-vray3.max/5SWR)
- hit render → result A
- change VRayLight parameters from Temperature: 5500,0 to something like 2000,0 (or 100,0 anyway) and back
- hit render → result B
I think he means that if he changes the WB value after rendering, then changes it back immediately to the value before (which in theory should produce the same image) does not produce the same image.
Hi guys, I am sorry for my late reply. I just came back from some holidays.
It is exactly like Art48 wrote. No matter if I am using Vray Advanced or Vray RT.
The issue occurs with several files I opened. Theses scenes were saved with Vray 3.0 or higher. But I can not reproduce it with a new scene.
